Field Affector
Field Affector
Updated: 8 Jan 2026
Allows particles to be affected by forces from a field.
This node samples velocities from a Field node and applies them to particles. This can be used to apply motions generated on a field, e.g. via a fluid solver, and apply them to a particle system so the particles move with the field. The magnitude of the velocity is controlled by the Velocity Scale attribute and modulated by a random value which is constant per particle and weighted by the Randomness attribute.
Optical Flow nodes can also be accepted to drive particles based on a video feed.
This node requires a Field or Optical Flow node to be connected via the Field input.
Apply Mode Select whether the field force are applied as simple velocities or continuous forces.
Field NodeThe field root node to useField 3D Root
