Angled Motion Affector
Updated: 15 Dec 2025
Moves particles via a noise field, with directions that are constrained to an angle.
This node moves particles via a noise field, with directions that are constrained to an angle - allowing for example motions constrained to square patterns.
Velocity Amount Amount of velocity to add to the particles movement.
Direction Angle Restriction Restrict the angle of which the motion will be applied. Restricts movement of the particle to certain angles.
Axis Axis on which to apply velocity.
  • 2D - YZ : Apply motion only along the Y and Z axis.
  • 2D - XZ : Apply motion only along the X and Z axis.
  • 2D - XY : Apply motion only along the X and Y axis.
  • 3D : Apply motion along the X,Y and Z axis.
Speed Variation How much variation there is in the speed each time the particle direction changes.
Position Random Scale The probability that the direction will change based on “Direction Change Rate - Position”.
Time Random Scale The probability that the direction will change based on “Direction Change Rate - Time”.
Direction Change Rate - Position TBC
Direction Change Rate - Time The rate at which the particles will change direction based on time. Lower value means the direction will change less frequently.
Randomness Sets random speeds for each particle. Will stay consistent for the life of the particle
Radius Radius of the affector’s falloff.
Inner Radius Inner radius off the affectors falloff.
Falloff Shape Select which method to calculate the falloff.
  • Point : Falloff is drawn outward from a point.
  • Line : Falloff is drawn outward from a Line .
  • Plane : Falloff is drawn outward from a plane.
Velocity TransformCan be used to apply an additional transform to the velocities generated by the node.Null
