Proximity Modifier
Proximity Modifier
Generates a modifier value from its distance to a transform.
This node generates values based on the distance between the nodes current position and the position of an input “tracked” position. Useful for checking if a node has moved within range of another, or measuring how close a node is to another node.
The node only calculates distance based on the origin of the input node, so objects with large bounding boxes should be tested with this in mind.
Blend Amount The amount to blend the input modifier’s value with it’s new value.
Inner Distance Inner range, the distance where the maximum value is applied.
Outer Distance Outer range, within which values will be generated linearly to the inner distance.
Use X / Y / Z Select which axis are used when calculating proximity distance.
These properties control the 3D transforms of the point to draw proximity to.
Position X / Y / Z Set the position for which you want to test if any target nodes are in range of.
Target NodeThe node which will be tracked.Null
