Perception Neuron Mocap Skeleton
Updated: 20 Jan 2026
Control skeletal rigs from a Perception Nueron system.
This node reads bone data from a Perception Neuron motion capture suit and applies it to Bone nodes, either via direct input links or by a connection to the root of the target hierarchy. A network connection must be made to the Axis Neuron software which provides a stream of bone data from the suit. The server address and port must be entered to match the output address and port in Axis Neuron. If there is no connection the node will be hatched out in red.
Axis Neuron Server Address The address / IP of the Axis Neuron server providing the skeleton stream.
Axis Neuron Server Port The port of the Axis Neuron server providing the skeleton stream.
Avatar Index Select the mocap actor to drive the skeleton.
Input Skeleton Scale Uniformly scale the size of the input mocap skeleton.
Hierarchy RootThe root of the input skeleton to be driven by motion capture.You’ll need to connect the skeleton root within an 3D Scene.
Mocap StreamInput a pre-recorded mocap stream to run instead of any live data.Mocap Stream
