Subsurface Scattering Material
Updated: 2 Feb 2026
A subsurface scattering material.
Subsurface Scattering is a technique that simulates how light penetrates the surface of translucent materials (like skin, milk, or wax), scatters within the material, and then exits at a different point. This effect creates a softer, more realistic appearance, especially for materials with depth, where light interacts below the surface.
This material needs the Path tracer node to function.
  • Solid : The material is solid, and does not blend with the scene.
  • Blend : The material is blended with the scene, allowing for transparency.
  • Clip : The material is clipped, only rendering the opaque parts.
  • Subsurface Scattering : The material simulates the scattering of light beneath its surface, allowing for a more realistic representation of materials like skin or wax. Controlled by Absorption Colour, Subsurface WWeight and Subsurface Scatter Radius controls.
  • Single Sided SSS : The material simulates subsurface scattering, but only on one side. Controlled by Absorption Colour, Subsurface Weight and Subsurface Scatter Radius controls.
  • Full Reflections : Calculates physically accurate, raytraced reflections from other objects and the environment in the scene.
  • Env Map : Uses a pre-rendered environment map for fast, approximate reflections instead of raytracing.
  • Off : Disables all reflections for this material, making it appear matte.
Glow Controls the glow.
This node has no inputs.
