Substance Material
Substance Material
Updated: 2 Feb 2026
Add an imported SBSAR material from Substance.
Notch allows the use of materials made with Substance Designer from Adobe. The Substance Designer Material once assigned to an object will behave like a standard Notch material. All options are identical, but with the ability to modify the texture on the fly according to the Substance parameters.
For more information about Substance Designer, visit their website.
By default, textures are not automatically cached. To do this, right-click on the node in the nodegraph and select Substance Material Options > Cache Substance Textures. A new material node will be generated with the textures from substance applied, and the textures will be added to the resource view.
It isn’t a necessity to cache the textures, this is only if you want to use one of the generated textures as a normal texture, and apply a filter to it for example.
Substance SBS Substance SBS File to generate textures from.
Substance SBS Preset Preset in the Substance SBS file to use.
Output Width Output width (pixels) of the generated textures.
Output Height Output height (pixels) of the generated textures.
  • Solid : The material is solid, and does not blend with the scene.
  • Blend : The material is blended with the scene, allowing for transparency.
  • Clip : The material is clipped, only rendering the opaque parts.
  • Off : No Translucency
  • Refraction : Translucency with refraction. Simulates the bending of light as it passes through a material. Controlled by IOR, Aberration, Absorption, Absorption Colour and Diffuse Coat controls.
  • Subsurface Scattering : The material simulates the scattering of light beneath its surface, allowing for a more realistic representation of materials like skin or wax. Controlled by Absorption Colour, Subsurface WWeight and Subsurface Scatter Radius controls.
  • Single Sided SSS : The material simulates subsurface scattering, but only on one side. Controlled by Absorption Colour, Subsurface Weight and Subsurface Scatter Radius controls.
  • Off : Disables lighting; the material displays its base colour only.
  • On : Enables the material to be affected by scene lighting.
  • Full Reflections : Calculates physically accurate, raytraced reflections from other objects and the environment in the scene.
  • Env Map : Uses a pre-rendered environment map for fast, approximate reflections instead of raytracing.
  • Off : Disables all reflections for this material, making it appear matte.
  • Full : The object is fully visible to the camera and appears normally in reflections and refractions.
  • Unseen by Rays : The object is visible directly to the camera but is invisible in reflections and refractions.
  • Unseen by Camera : The object is invisible to the camera but still appears in reflections and refractions.
