Shadow Catcher Material
Updated: 2 Feb 2026
Captures shadows and generates a diffuse alpha blended material.
The shadow catcher node captures shadow information from lights cast on to the surface of an object that has the shadow catcher material applied to it.
The captured shadow information can then be rendered separately onto surfaces of a scene using the layers composite blend modes alpha channels. This will give you the ability to render shadows onto objects not in the scene - for instance on real-world objects or floors in AR projects.
The shadow catcher node is great for adding shadows onto surfaces for AR projects.
  • Solid : The material is solid, and does not blend with the scene.
  • Blend : The material is blended with the scene, allowing for transparency.
  • Clip : The material is clipped, only rendering the opaque parts.
  • Off : Disables the use of the diffuse map for AO.
  • On : Enables the use of the diffuse map for AO.
  • Off : Disables lighting; the material displays its base colour only.
  • On : Enables the material to be affected by scene lighting.
  • Shadow Catcher : Use shadow catcher which allows a transparent background.
  • Shadow Catcher (RGB) : Use shadow catcher which outputs only a greyscale shadow texture.
Shadow Catcher Blend Blend amount of the shadows in the material.
  • Full : The object is fully visible to the camera and appears normally in reflections and refractions.
  • Unseen by Rays : The object is visible directly to the camera but is invisible in reflections and refractions.
  • Unseen by Camera : The object is invisible to the camera but still appears in reflections and refractions.
This node has no inputs.
