Metallic Material
Metallic Material
Updated: 2 Feb 2026
Add a metallic material.
This node generates a basic metallic material, similar to the default material node but default metallic settings.
  • Off : Disables lighting; the material displays its base colour only.
  • On : Enables the material to be affected by scene lighting.
  • Full Reflections : Calculates physically accurate, raytraced reflections from other objects and the environment in the scene.
  • Env Map : Uses a pre-rendered environment map for fast, approximate reflections instead of raytracing.
  • Off : Disables all reflections for this material, making it appear matte.
  • Full : The object is fully visible to the camera and appears normally in reflections and refractions.
  • Unseen by Rays : The object is visible directly to the camera but is invisible in reflections and refractions.
  • Unseen by Camera : The object is invisible to the camera but still appears in reflections and refractions.
This node has no inputs.
