Glass Material
Updated: 2 Feb 2026
Add a transparent glass material.
Updated: 2 Feb 2026
This node generates a basic glass material, similar to the default material node but with default raytraced glass settings.
| Colour Map -> Specular Colour | Use the input colour map as the specular reflection colour. |
| Normal Map Mode |
| Translucency |
| UV Texture Filter Mode |
| Diffuse Map -> AO |
A setting to use the Diffuse or Colour map to contribute to the Ambient Occlusion calculation, often darkening areas based on the base color.
| Subsurface Colour Map UV | Select the UV for the Subsurface Colour Texture. |
| Subsurface Weight Map UV | Select the UV for the Subsurface Weight Texture. |
| Texture Wrap Mode U |
| Texture Wrap Mode V |
| Reflections Mode |
| Shadows |
| Raytracing Settings |
| Polygon Sidedness |
| Vertex Colours - Apply To Alpha | Set how the vertex colours apply to the alpha of the mesh. |
This node has no inputs.
