Diffuse Material
Diffuse Material
Updated: 2 Feb 2026
Add a diffuse rough material.
This node generates a basic diffuse material, similar to the default material node but without any specular settings.
  • Off : Disables the use of the diffuse map for AO.
  • On : Enables the use of the diffuse map for AO.
This node has no inputs.
