Decal
Decal
Updated: 2 Feb 2026
Add decals to surfaces in the scene
This node projects images directly onto surfaces within a 3D environment. Instead of altering the original texture, the decal “layers” over it, allowing you to add visual effects like dirt marks, graffiti, impact marks, or other details. This approach makes adding visual details more flexible and resource-efficient, as it avoids the need to recreate or overload the original textures for each new visual addition.
Mapping Type Controls how the texture is applied to the surface.
  • Planar : Applies the texture in a flat, 2D manner.
  • Perspective : Applies the texture with perspective distortion.
Colour Controls the base colour of the material.
Blend Mode Controls how the Decal blends with the existing object material.
  • Linear Straight : Blends the decal linearly without any additional effects.
  • Linear Pre Mul : Blends the decal with pre-multiplied alpha.
  • Add : Blends the decal by adding its colour to the underlying surface.
  • Subtract : Blends the decal by subtracting its colour from the underlying surface.
  • Multiply : Blends the decal by multiplying its colour with the underlying surface.
Blend Amount Controls the strength of the blend effect.
Double Sided Controls whether the Decal is applied to both sides of the mesh.
Normal Angle Threshold Uses normals to determine the max angle at which the decal is applied.
Normal Angle Fade Controls the softness of the edge of the decal based on the angle of the surface normal.
Texture Filter Mode Controls the filtering method used for the texture.
  • Point : Each pixel is mapped to the nearest texel.
  • Bilinear : Uses linear interpolation between adjacent texels.
  • Anisotropic : Samples multiple texels along the direction of the surface.
Texture Wrap Mode U Controls the wrapping mode for the texture in the U direction.
  • Repeat : Repeats the texture in the U direction.
  • Clamp : Clamps the texture coordinates to the [0,1] range in the U direction.
Texture Wrap Mode V Controls the wrapping mode for the texture in the V direction.
  • Repeat : Repeats the texture in the V direction.
  • Clamp : Clamps the texture coordinates to the [0,1] range in the V direction.
Show Guides Displays guides for lining up the decal.
Show Projection Bounds Displays the projection bounds of the decal.
These properties control the decal output mapping in UV space.
Use Image Aspect Ratio Uses the input image aspect ratio.
Flip X Flips the texture on the ‘X’ axis.
Flip Y Flips the texture on the ‘Y’ axis.
These properties control where the deformer affects the geometry.
Enabled Enable falloff from the position of the deformer.
Shape Select which shape to use to draw falloff from.
  • Sphere : Falloff is drawn outward from a central point, forming a spherical falloff.
  • Cylinder : Falloff is drawn outward from a line, forming a cylindrical falloff.
  • Plane : Falloff is drawn outward from a plane.
Shape Orientation Along which axis the shape should be drawn.
Outer Range The outer range from which the falloff is calculated from.
Inner Range The inner range from which the falloff is calculated from.
Curve Power How quickly the falloff drops to 0 at the outer falloff.
Invert Invert the direction of the falloff.
ImageInput image to be used as a Decal.Video Loader
Affected Object NodesApplies the Decal to the specified object nodes.3D Primitive
Excluded Object NodesPrevents the Decal from being applied to the specified object nodes.3D Primitive
Projection TransformCopies the transform of the input node, and uses it to project the Decal onto the surface.Null
