Alpha Material
Alpha Material
Updated: 2 Feb 2026
Add a basic transparent material using a alpha blending.
Brightness How much light the object absorbs and doesn’t reflect back into the scene.
Specular Intensity Intensity of the specular reflections
Specular Colour The colour of specular light reflected from the material.
Specular Anisotrophy Change the shape of the specular highlight.
Metallicness Change how metallic the object looks.
Roughness How rough the surface of the material is.
Emissiveness How much of a glow is emitted around the object. Requires “high dynamic range” to be turned on in the root.
  • Solid : The material is solid, and does not blend with the scene.
  • Blend : The material is blended with the scene, allowing for transparency.
  • Clip : The material is clipped, only rendering the opaque parts.
  • Off : No Translucency
  • Refraction : Translucency with refraction. Simulates the bending of light as it passes through a material. Controlled by IOR, Aberration, Absorption, Absorption Colour and Diffuse Coat controls.
  • Subsurface Scattering : The material simulates the scattering of light beneath its surface, allowing for a more realistic representation of materials like skin or wax. Controlled by Absorption Colour, Subsurface WWeight and Subsurface Scatter Radius controls.
  • Single Sided SSS : The material simulates subsurface scattering, but only on one side. Controlled by Absorption Colour, Subsurface Weight and Subsurface Scatter Radius controls.
  • Off : Disables the use of the diffuse map for AO.
  • On : Enables the use of the diffuse map for AO.
  • Off : Disables lighting; the material displays its base colour only.
  • On : Enables the material to be affected by scene lighting.
  • Full Reflections : Calculates physically accurate, raytraced reflections from other objects and the environment in the scene.
  • Env Map : Uses a pre-rendered environment map for fast, approximate reflections instead of raytracing.
  • Off : Disables all reflections for this material, making it appear matte.
