State Machine
Updated: 2 Feb 2026
The Root controller for a state machine system.
Updated: 2 Feb 2026
The definition of a state machine is: a logic device which can be in one of a set number of stable conditions depending on its previous condition and on the present values of its inputs.
In a Notch State Machine system, Only one state can be active at a single time and the transition from one state to another state is triggered by an event.
As such, we have two associated nodes:
The State Machine node acts as mini-root node that is the parent to State Machine State nodes. The first vertically ordered state will be the initial state of the state machine.
| Current State | Reports the name of the current State Machine State node that is active. |
