Spot Light
Updated: 29 Jan 2026
Add a Spot Light
Add a Spot Light
Add a Spot Light node into the scene.
Attach the Target Node input to any object, to have the light track that object.
| Scale Y | The objects scale along the local x-axis. |
| Scale Z | The objects scale along the local x-axis. |
| Colour | The colour of the light. |
| Light Cone Angle | Change the size of the area the light covers. |
| Light Inner Cone Angle | Change the inner angle of the lights focus. |
| Brightness | How bright the light is. |
| Scattering Intensity | How much the light is scattered by the light, creating a simple fog around it. |
| Falloff Mode |
Change how the light falloff is calculated.
| Attenuation Distance | Maximum distance the light reaches. |
| Falloff Power | Change how strong the falloff for the light is between the Inner Attenuation Distance and the Attenuation Distance. |
| Penumbra Falloff Power | How quickly the edges of the spotlight falloff. |
| Apply Specular | Enable/Disable specular lighting. |
| Apply Diffuse | Enable/disable diffuse lighting. |
| Projection Image | Select an image to be projected from the light. |
| Projection Map Amount | How much the image affects the projection. |
| IES Profile | IES light profiles are published lighting profiles from manufacturers that show the lighting energy and patterns produced by their lighting systems. Notch is able to use these profiles to accurately replicate real-world lighting in its environments. A good resource site for these profiles can be found here. |
| Show Light Cone | Show a cone in the scene to represent the lights current position and rotation. |
| Casts Shadows | Toggle whether baked shadows are applied to the objects lit by the light node. |
| Shadow Softness | Change how much softness is applied to the shadow edges. |
| Z Bias | Increasing Z bias will improve the accuracy of grounding objects to their shadows. |
| Projection Image | Add in an image to be projected by the light. Useful for adding gobos to lights, or making a simple projector light. Only works when the Light Type is set to Spot. | Video Loader |
| Affected Nodes | Choose which nodes are affected by the light node. By default, all are affected. | 3D Object |
| Excluded Nodes | Choose which nodes are excluded from the light node. By default, none are ecluded. | 3D Object |
| Texture Projection Node | Controls the direction the image is projected from, independant of the light. Only functions if an image is being projected from the light. | Null |
| Multi-Source Controller | Deprecated feature. | |
