Omni Light
Omni Light
Updated: 29 Jan 2026
Add an Omni Light
Adds an Omni Light node into the scene, which casts light in all directions around it.
Falloff Mode Change how the light falloff is calculated.
  • Inner / Outer Radius (Legacy) : light falloff is calculated between the inner and outer radii.
  • Inv-Squared Distance (Physical) : the light falloff is calculated based on a physically accurate system.
Attenuation Distance Inner distance within which the light remains at full strength
Falloff Power Change how strong the falloff for the light is between the Inner Attenuation Distance and the Attenuation Distance.
Apply Specular Enable/disable specular lighting.
Apply Diffuse Enable/disable diffuse lighting.
IES Profile IES light profiles are published lighting profiles from manufacturers that show the lighting energy and patterns produced by their lighting systems. Notch is able to use these profiles to accurately replicate real-world lighting in its environments. A good resource site for these profiles can be found here.
Show Light Cone Show a cone in the scene to represent the lights current position and rotation.
Casts Shadows Toggle whether baked shadows are applied to the objects lit by the light node.
Shadow Softness Toggle whether baked shadows are applied to the objects lit by the light node.
Z Bias Toggle whether baked shadows are applied to the objects lit by the light node.
Projection ImageDeprecated feature. Projection images should not be used with omni lights.Video Loader
Multi-Source ControllerDeprecated feature.
