Light
Light
Updated: 29 Jan 2026
Add a point or spot Light.
Add a Light node into the scene.
Attach the Target Node input to any object, to have the light track that object.
The default light node is a spotlight, in the node properties use the Light Type drop-down menu to toggle between Spot, Omni.
Light Type Choose which type of light is used in the scene.
  • Spot : light is emitted from a point within a restricted cone.
  • Omni : light is emitted in all directions from a point.
Lighting Model Sets light to physically based or legacy
  • Inner / Outer Radius (Legacy) : light falloff is calculated between the inner and outer radii.
  • Inv-Squared Distance (Physical) : the light falloff is calculated based on a physically accurate system.
Light Cone Angle Change the size of the area the light covers. Only usable with the spotlight selected in the “Light Type” attribute.
Light Inner Cone Angle Change the inner angle of the lights focus.
Falloff Mode Change how the light falloff is calculated.
Inner Attenuation Distance Inner distance within which the light remains at full strength
Attenuation Distance Maximum distance the light reaches.
Falloff Power Change how strong the falloff for the light is between the Inner Attenuation Distance and the Attenuation Distance.
Penumbra Falloff Power How quickly the edges of the spotlight falloff.
Apply Specular Control whether this light applies specular light onto objects.
Apply Diffuse Control whether this light applies diffuse light onto objects.
Projection Image Select an image to be projected from the light.
Projection Map Amount How much the image affects the projection.
IES Profile IES light profiles are published lighting profiles from manufacturers that show the lighting energy and patterns produced by their lighting systems. Notch is able to use these profiles to accurately replicate real-world lighting in its environments. A good resource site for these profiles can be found here.
Show Light Cone Show a cone in the scene to represent the lights current position and rotation.
These properties control shadow properties from the light.
Casts Shadows Toggle whether baked shadows are applied to the objects lit by the light node.
Shadow Softness Change how much softness is applied to the shadow edges.
Z Bias Increasing Z bias will improve the accuracy of grounding objects to their shadows.
Projection ImageAdd in an image to be projected by the light. Useful for adding gobos to lights, or making a simple projector light. Only works when the Light Type is set to Spot.Video Loader
Multi-Source ControllerDeprecated feature.
