QR Code
Updated: 2 Feb 2026
Generates a QR code image
Updated: 2 Feb 2026
This node generates an image of a QR code from a given string. A QR code is simply an encoded string of text, and so are ideal as a quick link to a URL. The generated QR code is adaptive, and so will expand and contract based on the length of text added as it needs to.
Although most QR codes are predominately black and white, they do not have to be. A QR code can be any colour and can even include more than 2 different colours. The key takeaway is that the QR scanner is able to distinguish between foreground and background modules (the squares) in order to detect the pattern and decode the string contained within it.
| Preview In Viewport |
| Update Time Mode |
| Text String | The string of text to encode in the QR code. |
| Error Correction Level |
The error correction level. A higher ECC level will yield a barcode that tolerates more damaged parts while preserving the payload data.
| Version Range Min | The minimum version range. Different versions have a different amount of modules. Eg. Version 1 has 21x21 modules and version 40 has 177x177 modules. |
| Version Range Max | The maximum version range. Different versions have a different amount of modules. Eg. Version 1 has 21x21 modules and version 40 has 177x177 modules. |
| Border (in Modules) | The size of the border around the modules within the QR code. |
| Blend Mode |
