Render To Object Surface
Updated: 2 Feb 2026
Apply the field to the surface of geometry.
The field is sampled spatially on to the surfaces of visible 3D objects. This is useful for generating fluid effects onto nearby surfaces, and because its volumetric, the generated effect can be applied to the UV map of the 3D object, and rendered out with the UV Camera.
The Render to Object Surface node should be parented to the Field 3D Root node.
This node will not function with the default or Standard Renderer. Consider using the Hybrid Renderer or greater.
Blend Amount Changes the alpha of the field.
Brightness Changes the brightness of the field.
Sort Bias Biases the alpha sort in order to make it render in front or behind other transparent objects.
Velocity Alpha Scale The amount the velocity of the field is scaled when it is used to modulate alpha.
Blend Mode How the render blends with the objects original material colours. See Blend Modes for details.
  • Solid : The field rendering entirely replcaes the original surfaces colour.
  • Blend : The field rendering blends with the original surfaces colour, using the alpha channel.
  • Additive : The field rendering adds onto the original surfaces colour.
  • Subtractive : The field rendering subtracts from the original surfaces colour.
  • Multiply : The field rendering multiplies with the original surfaces colour.
  • Max : The max value between the field and the original surfaces colour.
  • Min : The min value between the field and the original surfaces colour.
  • Light : The field rendering is blended using the light blend mode with the original surfaces colour.
  • Screen : The field rendering is blended using the screen blend mode with the original surfaces colour.
  • Pre-Mul Blend : The field rendering mis premultiplied before blending with the original surfaces colour. Usually gives the best results for colour blending.
Use Field Alpha Channel Use the field alpha channel when blending with the original surface.
Velocity To Alpha Toggle whether the velocity amount is used to modulate the alpha value, so areas of faster movement are more visible.
Affected Object NodesLimit the field to only affect a connected piece of geometry. With no object connected, the field will affect all surfaces within the field bounding box.3D Object
Field SourceThe input field source.Field 3d Root
