Field 3D Renderer
Field 3D Renderer
Updated: 2 Feb 2026
Renders a 3D field via path tracing.
Renders a 3D field via path tracing. A Field Material is necessary to control how the field is rendered and shaded.
Fields are rendered lit using the scene’s lights. The Affecting Lights and Excluded Lights can be used to control which lights are applied. If there are no lights in the scene the field will render black.
This node can also be used to visualise the field’s channels.
The node should be parented to a Field 3D Root node.
Alpha Changes the alpha of the field.
Edge Fade Distance Controls at what distance from the edge of the bounds you want the filed to start fading to black at.
Sharpen Amount Control how sharp the field appears.
Visualise Mode Visualises different channels of the field.
Light Mode Set the method in which lighting is calculated
  • Fast : TBC
  • Sampled : TBC
  • All Scene : TBC
Shadow Mode Set the method in which the shadows are calculated.
  • Accurate : Set shadow quality to favour accuracy.
  • Fast : Set shadow quality to favour performance.
Local Ambient Occlusion Turn local ambient occlusion on.
AO Amount Control the level of local ambient occlusion applied to the field system.
Filtering Set the method of noise filtering.
  • Full : Apply all noise filtering types.
  • Temporal : Apply temporal noise filtering.
  • Spatial : Apply spatial noise filtering.
  • None : Don’t apply any noise filtering
MaterialInput a material to control how the field reacts to lighting.Field Cloud Material
Affecting LightsControls which scene lights are able to affect the field system.Light
Excluded LightsControls which scene lights will be excluded from affecting the field system.Light
