Field 2D Renderer
Field 2D Renderer
Updated: 2 Feb 2026
Renders a field system as a volume.
Renders a 2D field system as a 2D plane, which can then be composited with a larger scene. The node should be parented to a Field 2D Root node.
Alpha Changes the alpha of the field.
Brightness Changes the brightness of the field.
Sort Bias Biases the alpha sort in order to make it render in front or behind other transparent objects.
Velocity Alpha Scale The amount the velocity of the field is scaled when it is used to modulate alpha.
Alpha Height Scale Defines the thickness when a 2D field is rendered as a 2.5d volumetric form.
Raymarch 3D Fields Use raymarching to render the field system instead of slices. Depending on the scene, it can either increase or decrease performance, with some improvement to the quality.
Blend Mode How the field blends with the rest of the content in a 3d scene. See Blend Modes for details.
  • Solid : The field rendering is treated as a solid object, and does not blend with anything behind it.
  • Blend : The field rendering blends with the rest of the content in the scene using the fields alpha channel.
  • Additive : The field rendering adds onto the rest of the content in the scene.
  • Subtractive : The field rendering subtracts from the rest of the content in the scene.
  • Multiply : The field rendering multiplies with the rest of the content in the scene.
  • Max : The max value between the field and the content beind it is used.
  • Min : The min value between the field and the content beind it is used.
  • Light : The field rendering is blended using the light blend mode with the rest of the content in the scene.
  • Screen : The field rendering is blended using the screen blend mode with the rest of the content in the scene.
  • Pre-Mul Blend : The field rendering mis premultiplied before blending with the rest of the content in the scene. Usually gives the best results for colour blending.
Velocity To Alpha Toggle whether the velocity amount is used to modulate the alpha value, so areas of faster movement are more visible.
Volumetric Controls whether a 2D field is rendered with thickness as a 2.5d volumetric form.
Num Slices Defines the number of slices used when the 2D field is rendered as volumetric.
Show Velocities Renders the field velocities to the scene. Useful for investigating a field system and identifying field behaviour origins.
