Field Flame Material
Updated: 2 Feb 2026
A 3D field material suitable for fire / flames.
A 3D field material suitable for fire / flames. The field density is used to control absorption and scattering, and the temperature of the field is used via black body simulation to output an emissive colour. The temperature is also used to control the opacity of smoke and flames: temperatures below the Smoke Max Visible Temperature value are rendered as smoke, temperatures above the Flame Visible Temperature value are rendered as flame.
The smoke and flame shading can be controlled separately with this material to some extent. The smoke opacity is controlled with the Smoke Density parameter. The flame opacity is controlled via the Flame Density parameter.
Flame Density Scales the density/opacity of the flames.
Flame Emissiveness Scales the emissive output.
Min Flame Temperature The temperature threshold above which cells are rendered as flames.
Temperature Limits If enabled, the temperature min and max values are used. otherwise the values from the field 3d root are used.
  • Use root temperature : Conform to the temperature limits set by the root.
  • Override : Override the root temperature limits.
Min Temperature (K) The minimum temperature of the field for black body simulation, in degrees kelvin.
Max Temperature(K) The maximum temperature of the field for black body simulation, in degrees kelvin.
Smoke Density Scales the density/opacity of the smoke.
Smoke Tint Colour Tints the smoke.
Smoke Scatter Colour Controls the ratio of scattering vs absorption per colour channel for the smoke.
Smoke Scattering The ratio of scattering vs absorption for the smoke.
Max Smoke Temperature The temperature threshold below which cells are rendered as smoke.
Density NodesShading node input for controlling the overall density of the field system.Fractal Noise
Colour NodesShading node input for controlling the overall colour of the field system.Fractal Noise
Emissive Colour NodesShading node input for controlling the overall emissive colour of the field system.Fractal Noise
Flame Colour RampColour ramp input to control the colour of the flame material.Colour Ramp
