Particle 3D Emitter
Particle 3D Emitter
Updated: 2 Feb 2026
Emits ink into a field from particles
This node generates colour/ink based on the positions and movement of particles from a particle system. The particles contribute both ink and velocities to the field.
Particle Radius The particle radius.
Emission Mode When to emit.
Colour The colour to emit.
Density The amount of density to emit.
Temperature The amount of temperature to emit.
Velocity The scale of the velocity to emit. velocities are generated from particle motion; a velocity scale of 1 emits the particle’s velocity as-is.
Hardness TBC
Fractal Noise Amount The amount of fractal noise to apply to the emitted density.
F Noise Scale The scale of the fractal noise.
F Noise Threshold The threshold to apply to the fractal noise.
Explode Velocity The explode velocity.
E Noise Scale The scale of the fractal noise used to generate the explode velocity.
E Noise Threshold The threshold to apply to the fractal noise used to generate the explode velocity.
Pyroclastic Displacement The amount of pyroclastic displacement.
P Noise Scale The scale of the fractal noise used to generate the pyroclastic displacement.
Particle NodeUsed to connect the particle system used by the emitter.Particle Root
Density NodesShading node input for controlling emitter density.Fractal Noise
Temperature NodesShading node input for controlling emitter temperature.Fractal Noise
Fuel NodesShading node input for controlling emitter fuel amount.Fractal Noise
Colour NodesShading node input for controlling emitter colour.Fractal Noise
Velocity NodesShading node input for controlling emitter velocity.Fractal Noise
