Particle 2D Emitter
Updated: 2 Feb 2026
Emits ink into a field from particles.
Updated: 2 Feb 2026
This node generates colour/ink based on the positions and movement of particles from a particle system. The particles contribute both ink and velocities to the field.
| Texture | Add a texture for the particles to use to emit into the field. |
| Intensity Scale | How strong the emitter is on the field. |
| Output Velocities | Toggle whether the velocities from the source particle system should be passed into the field. |
| Velocity Scale | Scale the generated affector velocities. |
| Particle Size | Control the size of the particles in the field system. |
| Size Randomness | Add randomness to the size of the particle emission shapes. |
| Particle X Scale | Scale each particles emission shape on the x axis. |
| Particle Y Scale | Scale each particles emission shape on the y axis. |
| Particle Scale Coeffs | TBC |
| Particle Alpha | Control the alpha value for each particle in the field. |
| Visible | Control the visibility value for each particle in the field. |
| Blur Mip Levels | Number of blur amount levels between near and far. |
| Rotation Randomness | Add randomness to the rotation of the particle emission shapes. |
| Luminance Randomness | Add randomness to the luminance, or brightness, of the particle emission. |
| Screen Size Limits | TBC |
| Motion Blur Amount | The amount of motion blur applied to the field system |
| Lit | Legacy, due to be removed |
| Casts Shadows | Legacy, due to be removed |
| Sort Particles | TBC |
| Blend Modes |
How the emitter blends into the field. See Blend Modes for details.
| Mipmap Enabled | Enables the use of Mipmaps at different distances from the camera. |
| Emission Mode | When to emit. |
These properties control spritesheet animation for input images which contain an animated texture.
| Use Texture Animation | Edit whether the texture animation is shown with the rendering. |
| Animation Rate | Edit whether the texture animation is shown with the rendering. |
| Num Frames X | Change how many tiles the sprite image will be spread across the x axis. |
| Num Frames Y | Change how many tiles the sprite image will be spread across the y axis. |
| Start Frame |
The method by which the start frame of the texture animation is chosen.
| Particle Node | The particle root used to generate the field. A particle system must be connected for this node to function. | Particle Root |
| Sprite Transform Node | Apply the transforms of another node to this node’s particle sprites, relative to its parent. | 3D Null |
| Image Node | Image or video to apply to each particle sprite | Video Loader |
| Density Nodes | Shading node input for controlling emitter density | Fractal Noise |
| Temperature Nodes | Shading node input for controlling emitter temperature | Fractal Noise |
| Fuel Nodes | Shading node input for controlling emitter fuel amount | Fractal Noise |
| Colour Nodes | Shading node input for controlling emitter colour | Fractal Noise |
| Velocity Nodes | Shading node input for controlling emitter velocity | Fractal Noise |
