Field - Field Emitter
Emits ink into a field from another input field.
This node emits colour/ink into a field by reading it from another input field.
Blend Mode How the emitter blends into the field. See Blend Modes for details.
  • Solid : The emitted ink replaces all the field.
  • Linear : The emitted ink is blended with the field.
  • Additive : The emitted ink is blended with the field.
  • Subtractive : The emitted ink is subtracted with the field.
Blend Amount How much the input field blends with the current field.
Emission Mode When to emit.
Colour Tint the colour of the original field system.
Output Velocities Toggles whether the velocities from the original field are output.
Velocity Scale Scale the generated velocities from the source field.
Output Colours Toggles whether the colours from the original field are output.
FieldThe field to be added into the current field system. A node must be connected to this input for this node to function.Field 2D Root Node
Colour RampAdds a colour gradient to the field.Colour Ramp
Density NodesShading node input for controlling emitter density.Fractal Noise
Temperature NodesShading node input for controlling emitter temperature.Fractal Noise
Fuel NodesShading node input for controlling emitter fuel amount.Fractal Noise
Colour NodesShading node input for controlling emitter colour.Fractal Noise
Velocity NodesShading node input for controlling emitter velocity.Fractal Noise
