Primitive Collision Affector
Updated: 2 Feb 2026
Allows fields to collide with primitive shapes.
This node allows fields to collide with the surface of primitive 3D shapes. The field will flow around or bounce off the shape’s surface and be prevented from entering it.
Shape Type Select a shape to model a collision with the field against.
  • Circle : Collide the field with a flat circle.
  • Sphere : Collide the field with a 3D sphere.
  • Ring : Collide the field with a 2D ring.
  • Torus : Collide the field with a 3D torus.
  • Box : Collide the field with a 3D box.
  • Plane : Collide the field with a 2D plane.
Collision Velocity. How much the field ink bounces off the colliding surface.
Radius Outer Outer radius of the selected shape.
Radius Inner Inner surface radius of the selected shape.
Invert Shape Invert the collision area, usually flipping the collisions from outside the mesh to inside the mesh.
