Turbulence Affector
Turbulence Affector
Updated: 2 Feb 2026
Applies turbulent velocities to a field.
This node applies turbulence to the movement vectors of a field system, applying a noisy motion with a large range of noise shapes.
Velocity Amount Scale the generated affector velocities.
Noise Scale Scale the size of the noise for the turbulence.
Noise Threshold Limit the low end noise that will be output to the field.
Mode Choose how the turbulence effect is calculated.
  • Repel : Pushes the fields away from the affector origin point.
  • Attract : Pulls the field towards the affectors origin point.
  • Turbulent : Pulls and pushes the field with turbulent forces.
Animation Rate How fast the turbulence noise animates.
Update Time Mode How the video is played in relation to the time code.
  • Locked To Timecode : The video is locked to the time code and the same time will always yield the same video frame.
  • Running / Looping : The video is disconnected from the time code and will loop seamlessly at the end of the layer.
Visualise Field Visualise the turbulence vectors in the viewport.
Velocity NodeA transform node that overrides the velocity direction and source position.Null
