Fluid 2D Affector
Fluid 2D Affector
Updated: 2 Feb 2026
Applies a fluid simulation to a field.
This node applies a fluid solver to the velocities of the field system, creating eddies and swirls like a gas or liquid. This solver uses the grid-based Navier Stokes method, maintaining incompressible pressures using multiple iterations of a process over the field’s voxel grid, and can have a sizeable performance impact with high-resolution fields.
Simulation Speed Controls the speed of the fluid simulation.
Vorticity Confinement Scale Controls the amount of vorticity confinement, which increases the number of small swirls in the fluid system.
Diffusion Amount How much the field colours are diffused to neighbouring voxels.
Velocity Dampening How much velocities are dampened and averaged across the field system.
Solver Iterations How many times the fluid system solver is run. Higher values improve accuracy, but lower performance.
