Field Affector
Field Affector
Updated: 2 Feb 2026
Applies a different field's velocities to a field.
This node uses the velocities of a separate field system and applies them to the current field system. This allows for ink to be disturbed by the motion of air, without rendering the air itself. An Optical Flow node can also be connected in a 2D field system, to control the field from the motion of a video.
Velocity Scale Scale the amount the input field affects the parent field system.
Field NodeThe field to be used by the affector. If no field is connected, this node will not function.Field 2D Root
Mask NodeMasks the areas in which the affector won’t apply.Image Plane
Affected EmittersControl which Emitters are affected by the Affector. By default, all emitters in the field system are affected.Primitive Emitter
Procedural FalloffInput to use a procedural system to control the falloffProcedural Root
