Point Deformer
Point Deformer
Updated: 3 Feb 2026
Deforms geometry by using input points as a transform source
This node is used to deform vertices using points from a particle system or the vertices of another 3D object. The closest points to each vertex are determined and a falloff calculated using the distance to those points, then displacement and colour modifications are applied to the vertex.
  • Local : Deformations are calculated in the Local Space of the object, so transformations of the parent mesh will not affect the deformation.
  • World : Deformations are calculated in the World Space of the scene, so transformations of the parent mesh will apply the deformer differently depending on the mesh position.
Point Displacement Mode The method by which the points are used to displace the vertices.
  • Displace : Move points along vertex normal.
  • Affect : Attract the vertexes to the point position.
  • Repel : Repel the vertexes to the point position.
Point Colour Mode How the points are used to colour the mesh vertex colours.
  • Point Colour : Vertexes are coloured based on the point colours.
  • Distance : Use the colour from the Colour property.
Point Falloff Distance The outer radius for each point where the deformer will no longer be effective.
Point Falloff Power The sharpness of the falloff from each point.
Point Normal Direction Weight Weights the effect of each point on the vertex by how much the mesh vertex normals points towards it. This allows points behind vertices to be ignored.
Colour Blend Amount The amount the new colour is applied to the vertex colours.
Colour The colour to apply to the mesh. Only functions with Distance enabled in the Point Colour Mode.
Point SourcePoint source from which to deform the Mesh.Particle Root
Mask ImageUse an image to mask out areas for the deformer to not function.Video Loader
