Curl Noise Deformer
Curl Noise Deformer
Updated: 3 Feb 2026
Deforms geometry based on a curl noise function
This node deforms a mesh based on a curl noise function, creating noisy displacement and somewhat random looking shapes.
  • Local : Deformations are calculated in the Local Space of the object, so transformations of the parent mesh will not affect the deformation.
  • World : Deformations are calculated in the World Space of the scene, so transformations of the parent mesh will apply the deformer differently depending on the mesh position.
Displacement Amount How much the deformer displaces the original mesh.
Noise Scale Scale the size of the generated curl noise.
Animation Speed Change the speed the deformer is simulated at.
Mask ImageUse an image to mask out areas for the deformer to not function.Video Loader
