Mesh Cloner
Mesh Cloner
Updated: 8 Jan 2026
Generates clones from input geometry.
This node creates clones at positions defined by another 3D object. The connected node must generate a mesh, such as a 3D Object, a 3D Primitive or a Text node.
Mode Select how the cloner clones from the source object.
  • Vertex : Clone the object to the source objects vertexes.
  • Polygon Centre : Clone the object to the centre of the polygons in the source object.
  • Edge Centre : Clone objects to the centre of the edges in the source object.
  • Spread Over Surface : Clones are spawned randomly on the surface of the object.
  • Spread Over UV Map : Spreads the clones across the UV map of the object.
Num UV Clones X Set the number of clones to spawn on the UV map and how many should spawn along the x axis.
Num UV Clones Y Set the number of clones to spawn on the UV map and how many should spawn along the y axis.
Randomise Mesh Order Use a random seed to dictate the order in which clones are spawned.
Randomise Order Seed Select a random seed to drive the effect,
Clone Offset From Surface How far the clones are spawned from the surface of the source object.
Random Position Offset Offset the position of the clone on the polygon randomly.
Random Position Offset Seed Set the seed for the random position generated by “Random Position Offset”.
Surface Spread Mode How the clones are spread to the surface of the source object. Only functions when “Spread Over Surface” is selected in the “Mode” attribute.
  • Normalised : Clones are spread out to fill the source object.
  • Fixed : Clones are spawned at the density set by the “Surface Spread Density Attribute”.
Surface Spread Density How dense the clones are once spawned. Only functions with “Normalised” chosen in the “Surface Spread Mode” attribute.
Use Undeformed Positions Generates the clones before the shape is deformed, so the clones will animate correctly but may not be spread out as nicely after deformation.
Rotation Mode How the clones should be oriented once spawned.
  • None : Spawned objects ignore the rotation of the source object.
  • Object : Spawned objects use the rotation of the source object.
  • Align To Normals : Spawned objects align their rotations with the normals of the object.
Scale Clones By Poly/Edge Size Toggle whether to scale the clones by the size of their poly/edge size (depending on which mode is selected in the “Mode” attribute).
Colour Clones Allow the clones to be coloured at generation.
Use Vertex Colours Use the colours of the nearest vertex to dictate colour of the clone.
Use Texture Colours Use the colours of the texture at the clones generated location to dictate colour.
Colour Cutoff Mode Change how the mesh texture cuts off certain clones.
  • Luminance : The luminance values of the mesh texture are used.
  • Alpha : The alpha values of the mesh texture are used.
  • Luminance * Alpha : Luminance values multiplied by the alpha values are used.
Colour Cutoff Limit how bright regions of the image must be for the clones to be spawned.
Weightmap Threshold Above what weightmap value will clones be allowed to spawn.
Weightmap Affects Scale When on the weightmap value will affect the scale of the clones.
Weightmap Scale Scale multiplier for “Weightmap Affects Scale”.
Source ObjectsSource mesh to generate clones from. A mesh must be connected for the cloner to generate clones.3D Object
WeightmapAdd a weightmap to vary the strength of the cloner across the surface.Generate Weightmap
