Turbulence Effector
Turbulence Effector
Updated: 3 Feb 2026
Modifies a cloner system with turbulent motion.
This node applies an animating turbulence to the transforms of clones, with animation and scale parameters to tweak the size and shape of the noise to the desired behaviour.
Lucanarity How large the gaps between larger areas of noise are.
Limit Noise Range Set the min and max range of the fractal noise values.
  • Linear : Apply positional values linearly
  • Circular : Apply positional values circularly
  • Spherical : Apply positional values spherically
Uniform Random Scale Uniformally scale the clones by the same value along all axes.
