Sound Effector
Sound Effector
Updated: 8 Jan 2026
Modifies a cloner system using an audio input.
This node applies a transform to clones based on the analysis of an audio source. The waveform is processed using a set of parameters, allowing for greater control over how the sound is applied to the clones.
Sound Sound used to drive the effector. Can be overwritten by adding a relevant node to the Sound input.
Channel Which audio channel is used.
Frequency Band Sets the Band EQ to one of the given presets.
Band EQ Selects and weights the frequency bands to be used from the sound file.
Time Offset Offset the time the clones are modified from the time the waveform is at.
Change Threshold Changes the threshold for what counts toward the effect.
Attack Controls the initial time between the current values to the peak.
Min Value Acts as a minimum threshold for extracting a range of values from the waveform.
Max Value Acts as a maximum threshold for extracting a range of values from the waveform.
Max Clamp A maximum value which values will be clamped if they go above.
Spikiness Accentuates peaks in the waveform so they are sharper.
Scale How much the output values are scaled.
Smoothness How much smoothing is applied between differing values.
FFT Sample Scale Scale the size of the waveform as it is applied.
Waveform Visualises the waveform of of the sound.
Direction Change how the sound is applied to the Cloner system.
  • Linear : The bands are spread along the x axis, and time progresses in the positive z axis.
  • Radial : The bands spread out radially around the z axis, and time progresses in the positive z axis.
  • Spherical : The bands spread out radially around the z axis, and time progresses in the negative z axis. Only position x is used to affect the clones.
SoundUse an input sound to override the sound attribute.Sound Loader
