Smoothing Effector
Smoothing Effector
Updated: 8 Jan 2026
Smooths changes in a clone's movement or scale.
This node can smooth changes in a clone’s position, rotation or scale. Each property can be individually controlled and has its own falloff settings. For example you could control the smoothing of rotation separately from the smoothing of position. This allows you to have more granular control over the smoothness of a cloner system.
Space The transform space in which the Effector is processed.
  • Effector - World : use the effector’s transforms in world space.
  • Cloner : use the cloner’s transform space.
Position Adaption Mode Set how to use falloff to influence the amount of positional adaptation applied to the clones.
  • Falloff : Use falloff to scale the position adaption rate.
  • Inv Falloff : Use the inverse of the falloff to scale the position adaption rate.
  • No Falloff : Use no falloff, so affect all clone’s position adaption rate equally.
  • Unsmoothed : Do not do any smoothing. Turn off the smoothing effect for positional changes.
Position Adaption Rate The rate at which position changes will adapt as a fraction per frame. A value of 0.5 will move 50% of the remaining distance per frame.
Rotation Adaption Mode Set how to use falloff to influence the amount of rotational adaptation applied to the clones.
  • Falloff : Use falloff to scale the rotation adaption rate.
  • Inv Falloff : Use the inverse of the falloff to scale the rotation adaption rate.
  • No Falloff : Use no falloff, so affect all clone’s rotation adaption rate equally.
  • Unsmoothed : Do not do any smoothing. Turn off the smoothing effect for rotational changes.
Rotation Adaption Rate The rate at which rotational changes will adapt as a fraction per frame. A value of 0.5 will rotate 50% of the remaining rotation per frame.
Scale Adaption Mode Set how to use falloff to influence the amount of scale adaptation applied to the clones.
  • Falloff : Use falloff to scale the scale adaption rate.
  • Inv Falloff : Use the inverse of the falloff to scale the scale adaption rate.
  • No Falloff : Use no falloff, so affect all clone’s scale adaption rate equally.
  • Unsmoothed : Do not do any smoothing. Turn off the smoothing effect for scale changes.
Scale Adaption Rate The rate at which scale changes will adapt as a fraction per frame. A value of 0.5 will scale 50% of the remaining scale value per frame.
Smoothing Node Mode Which other nodes this node will affect.
  • Effector Children : Will only affect nodes connected as children to this node.
  • Effectors In Chain : Will affect all nodes in the cloner chain.
