Spline Extruder
Spline Extruder
Updated: 28 Jan 2026
This node extrudes n-gon shapes along a spline.
This node generates a mesh from an input spline, by extruding a shape along the spline. The input spline can be modified via their control points, and the extruded mesh will dynamically update to match. Useful for making tubes and tunnels, as well as wires and ribbon effects.
A mesh can be used as input if it has the Object To Lines deformer. The Duplicate Spline deformer can also be used to easily draw multiple splines.
This node outputs the normal transformation and translation values, but it also outputs geometry which can be modified with Deformer nodes, or used as a mesh sources for nodes which accept mesh connections, such as the Field 3D Object Emitter or the Procedural 3D Object.
Num Spline Segments How many subdivisiones are added along the spline length during extrusion. Higher values can improve the smoothness of the curve, but increase the geometry count significantly and therefore can impact performance.
Spline Time Min The start point of the extruded mesh along the length of the spline, by a value normalised by the splines length.
Spline Time Max The end point of the extruded mesh along the length of the spline, by a value normalised by the splines length.
Spline Time Offset Offset the generated mesh by a value normalised over the splines length. When used with the Spline Time Min and Spline Time Max, can form a slice which moves along the spline.
Lock Subdivisions To Spline Time When enabled, the subdivisions along the spline will be treated as locked in place. The Spline Time Min/Max/Offset properties will not affect the subdivisions, instead the mesh topology will continually update to maintain a the existing topology. Useful for maintaining consistent polygon density, regardless of the length of the generated mesh.
Caps Should the extrusion have sealed caps on the ends.
  • None : Both ends of the extrusion will be open.
  • Single : One end of the extrusion will be closed, the other will be open.
  • Double : Both ends of the extrusion will be closed.
Extrude Shape The shape of the extruded n-gon.
  • Square : A square shape.
  • Ring : A ring shape. the num radial segments parameter controls the number of segments in the ring.
  • 2D Strip : A flat strip which is single-sided.
  • Thickened Strip : A flat strip which is slightly extruded to be solid.
  • Star : A star shape.
Num Radial Segments How many sides the extruded shape will have, in ring mode.
Radius The radius of the shape to be extruded along the spline.
Control Point Scaling Mode The method by which the scales from the interpolated control points scale the extruded spline’s extrusion from the spline.
  • None : Only the radius parameter and fade controls will be used to scale the spline.
  • Radius : Scale the extrusion in radius using the length of the control point’s xy scaling.
  • XY : Scale the extrusion using the control point’s xy scaling.
Radial Rotation Offset Used to control the rotation of the extruded geometry around the spline axis.
Use Spline Colours Use the colours from the input spline to
UV Mode Controls how the generated geometrys uvs are generated along the spline.
Fade Alpha Fade the alpha values of the generates spline along its length using fade front and back duration. requires an alpha supporting blend mode.
Fade Scale Scale the radial size of the spline using the fade front and back duration.
Fade Front Duration How long the front edge fades for as a percentage of the whole spline.
Fade Back Duration How long the back edge fades for as a percentage of the whole spline.
Minimise Self-Intersections If enabled, attempts to avoid the self-intersections that occur at tight corners in the spline by pushing the vertices away from the intersecting planes.
Spline SourcesSpline nodes used to draw the extrusion along.Spline
MaterialOverride the default material with a material node.Material
