Bounding Box
Bounding Box
Updated: 28 Jan 2026
A bounding zone for controlling other systems.
This node is a null transform node that internally generates a unit sized (-1 to 1) box. Often used to mark areas of space, such as bounding regions for fluid or volumetric effects.
Outputs from this node are generally connected to nodes which make use of a bounding box input, but the output is a simple transform so any node can be connected and the transforms will be inherited.
