Auto Bounding Box
Auto Bounding Box
Updated: 28 Jan 2026
A bounding box generated from another nodes bounds.
This node generates a bounding box based on the combined size of nodes input. Useful for quickly generating an area of effect for a field system, or getting the bounding size of a mesh for processing in a modifier system through a Extractor node.
Outputs from this node are generally connected to nodes which make use of a bounding box input, but the output is a simple transform so any node can be connected and the transforms will be inherited.
Expansion Expand or contract the bounds of the generated bounding box
Bounds NodesInput nodes from which a combined bounding box will be generated.3D Object
