2D Primitive
2D Primitive
Updated: 28 Jan 2025
Generates a 2D Primitive Mesh
This node generates a 2D primitive mesh, chosen from the nodes Shape Type property. Typically used in a 2D system under a 2D Root to generate simple 2D shapes, but is equally applicable to 3D scenes.
This node outputs the normal transformation and translation values, but it also outputs geometry which can be modified with Deformer nodes, or used as a mesh sources for nodes which accept mesh connections, such as the Field Mesh Emitter or the Procedural Mesh. A Material Node can also be input to control the meshes material properties.
Shape Type Choose which 2D shape is rendered.
  • Box : Simple box with capability for additional subdivisions and bevel.
  • Circle : Simple sphere with capability for additional subdivisions and an inner hole.
  • Capsule : Simple pill shape which generates dynamically based on the subdivisions and defined size.
  • Arrow : Simple Arrow shape with various controls over arrow shape, width, length, subdivisions, and many more.
Size Mode Choose if the properties define the radius or diameter of the shape.
  • Radius : 1 unit measures the distance between center to the bounds.
  • Diameter : 1 unit measures the distance between the object bounds.
  • Corners : 1 unit measures from one corner to the opposite corner.
Size X Size of the object along the X axis
Size Y Size of the object along the Y axis
Bevel Radius The radius of the rounded corners of the object.
Bevel Subdivisions Number of subdivisions used to form the bevel.
Box Subdivisions X Number of subdivisions used for the Box shape on the X axis.
Box Subdivisions Y Number of subdivisions used for the Box shape on the Y axis.
Origin X Set the objects origin point for the X axis.
  • -Size : Sets the objects origin to the objects bound in the negative X direction.
  • Centre (Zero) : Sets the objects origin to the objects center.
  • +Size : Sets the objects origin to the objects bound in the positive X direction.
Origin Y Set the objects origin point for the Y axis.
  • -Size : Sets the objects origin to the objects bound in the negative Y direction.
  • +Size : Sets the objects origin to the objects bound in the positive Y direction.
Primitive Vertex Count Shows the original vertex count of the primitive at generation.
Primitive Polygon Count Shows the original polygon count of the primitive at generation.
Post-Deformer Vertex Count Shows the current vertex count of the primitive after all the deformers have been applied.
Post-Deformer Polygon Count Shows the current polygon count of the primitive after all the deformers have been applied.
Render Z Only When enabled, the 3D object is only rendered to the depth buffer in the main camera render. No colour data is rendered.
Render To Shadows Only When enabled, this object isn’t rendered to the camera but will render shadows still.
These properties control how the UVs of the mesh are transformed when output for the UV camera. Useful for arranging multiple objects to be output for the same UV Camera.
Show Metrics TBC
These properties control the behavious of the object in a Physics System.
  • Static : A static rigid body does not move and can’t be moved by physics, but will act as a collider for other dynamic objects. An example could be a floor or wall.
  • Kinematic : A kinematic rigid body is not moved by physics but has a velocity that can affect dynamic bodies. An example could be a moving platform or rotating collider.
  • Dynamic After Collision : A dynamic rigid body has its initial position set by its transform, but transform control is taken over by physics as soon as the object collides.
  • Disabled : Physics will not be applied, and the object will be ignored for simulation.
  • Baked : All the rigid body’s transforms will be controlled by the baked physics data.
GPU Transform Only If selected, the transform of the body is maintained on GPU only. This reduces latency and increases performance but means that parenting to the object, e.g. using it to transform lights or emitters, will not work.
  • 14 Faces (Capsule) - X-Axis : A simplified capsule with 10 sides pointing along the X axis.
  • 14 Faces (Capsule) - Y-Axis : A simplified capsule with 10 sides pointing along the Y axis.
  • 14 Faces (Capsule) - Z-Axis : A simplified capsule with 10 sides pointing along the Z axis.
  • Sphere : A sphere, useful for emulating balls or roundish objects.
  • Box : A box, useful for emulating boxy objects.
  • Plane : A flat infinite plane, useful for setting up solid walls. May only be static or kinematic.
  • 3D Object (Convex Hull) : A convex hull derived from the geometry of the node, with its own modes to set the convex hull generation below.
  • 3D Object (Use Original Geometry) : The original triangle geometry of the node, if applicable. Best used with low poly meshes.
Bake Physics Transforms Bake physics transforms so they are no longer dynamic, but reliably playback and are more performant.
Baked Transform Select the baked physics transform.
  • Linear : The line rendering is blended with the rest of the content in the scene.
Colour TextureOverride the default material with a material node.Video Loader
