Temporal Filter
Temporal Filter
Combines multiple frames together and filters out overlapping values.
This node combines multiple frames together and filters out overlapping values.
Mode How the next frame is generated based on the frames before it.
  • Min : The minimum value override the current value.
  • Max : The maximum value override the current value.
  • Average : The average of the values overrides the current value.
Num Frames The number of frames previous to the current frame used in the filter.
