Using Notch in Hippotizer
Updated: 20 Nov 2025
Green Hippo have native Notch playback support from version 4.2 (patch required)
To preview or play content in Hippotizer you will need either :
Hippotizer ships with a set of 10 in-built Notch effects which work with all Hippotizer+ products out of the box. If you wish to playback Notch content outside of these Hippotizer in-built effects (i.e. custom blocks or Notch created blocks), you will require a full Notch Playback License.
