Kinect Surface Mask
Kinect Surface Mask
Updated: 7 Oct 2025
Creates a image representing surface of the kinect data.
This node creates an image representing the surface of the kinect data and colours it by the normal direction of surface.
Surface Heading Offset the surfaces Y direction value from its current direction.
Surface Pitch Offset the surfaces Z direction value from its current direction.
Falloff The strength of the effect.
Bounding BoxLimits the area that the effect will use.Bounding Box
