Bump Map Warp
Updated: 19 Feb 2025
Warps an image based off of a bump map.
This node warps an image based off of a bump map. The warp is generated by creating a copy of the image with a slight offset and multiplied. If there is no input connected to the Image Node input then the scene render is used as a source bump map.
| Displacement Amount | How much the warp effect displaces the image. |
| Falloff Range | How far the falloff for the warp reaches. |
| Displacement Amount X | How much the images are displaced along the x axis. |
| Displacement Amount Y | How much the images are displaced along the y axis. |
| Bias Displacement Direction (Grey = 0) | Change the displacement direction so that a middle grey value has no displacement, and values darker or brighter will push the displacement in opposite directions. |
| Normalise Displacement Direction | Force the displacement direction to apply evenly in each direction. this does not include alpha modulation. |
| Modulate Displacement Amount By Alpha | Control the strength of the displacement based on the input images alpha channel |
Control how much the RGBA channels displace the X and Y axes individually.
| Image Node | The source bump map for the warp. | Video Loader |
| Effect Amount Image | Input to control the amount of the effect based on the colour data of an image. | Gradient |
| Falloff Node | Add a gradient that controls how far the effect affects the image. | Gradient 2D |
