Cross Hatch
Cross Hatch
Updated: 24 Feb 2025
Add a cross hatch effect to an image.
This node adds a cross hatch effect. The image is broken up by brightness, and hatch texture is sectioned and overlaid onto the image. The brightness of the section in the original image determines which part of the hatch texture will be overlaid into that section.
The example below has had a hatch texture applied, the effect doesn’t work without a hatch texture selected and by default, none is applied.
Input Image
Hatch Texture The texture used as a hatch pattern.
Amount Change how strong the efffect is on the input image.
Hatch Texture Scale Change the scale of the cross hatching on the image.
Animation Rate The speed at which the cross hatching is animated.
Hatch TextureInput texture to be used as a hatch pattern. See example image for reference.Video Loader
