Output GBuffer
Updated: 24 Mar 2025
Render a layers GBuffers directly.
This node allows you to render one of the various GBuffers to the screen. GBuffers are geometry buffers - rendered images that contain geometric information rendered from the objects in the current view, such as normals, material IDs, positions etc. These may be useful when rendered and loaded into other software. This node can be connected to a Render Layer, Render to Texture, or the Root node - other nodes will output nothing.
Some channels will not work with the standard renderer. (Metalicness,Roughness…)
Composite Colour
Colour
Alpha
Depth Camera Space
Metalicness
Rougnhess
Specular Colour
Normal Camera Space
World position
Material ID
Object ID
Normal World Space
| Channel |
Select which gbuffer channel to output.
| Apply To Solid Geometry Only | Only apply the effect to solid geometry. Allows other objects in the scene to still be visible and un affected. |
| Render Layer | Select a specific render layer to output the GBuffer for. | Render Layer |
