Line Distortion
Updated: 24 Feb 2025
Add growing lines to an image.
This node distorts to an image by generating lines from each pixel, and varying their lengths based on luminance.
| Amount | How strong an effect will be applied to the image. |
| Rotation | Edit the rotation of the effect. |
| Sparseness | How close together all the lines are in the effect. |
| Threshold | The luminance threshold at which a pixel will contribute to the effect. |
| Line Wave Amount | How much the distorted lines lengthen and shorten in a vertical wave. |
| Line Width | Width of the lines used in the effect. |
