Turbulence Affector
Updated: 8 Aug 2025
Applies Turbulence to physics objects.Updated: 8 Aug 2025
Applies Turbulence to physics objects.This node applies turbulence to the motion of physics objects. This is typically used to apply local variations to physics objects motion, and simulate small gusts of wind. The motion is generated by using a smoothed noise field for both the direction and the magnitude of the applied velocity.
| Amount | Strength the affector has on the affected physics objects. |
| Noise Scale | Scale the size of the generated noise. Higher values will given denser and more erratic motion, while lower values will creater smoother and more stable motions. |
| Noise Threshold | Sets a minimum amount the noise must be pushing beyond to have an effect on the affected physics objects. |
| Animation Rate | How quickly the turbulence animated and changes over time. |
| Animation Time Offset | Manually control how the turbulence animation is changing oer time by offsetting it in time directly. |
| Update Time Mode |
Change how the affector uses time.
| Dampening | Softens the motion applied to the objects to smooth out any erratic motion from the affected physics objects. |
| Falloff Mode |
| Falloff Direction |
| Falloff Easing Mode |
