Force Affector
Updated: 8 Aug 2025
Allows forces to be applied to a physics objects.
Updated: 8 Aug 2025
This node applies a constant force on physics objects. This is typically used push and pull objects towards or away from the subject.
| Amount | Strength the affector has on the affected physics objects. |
| Dampening | Softens the motion applied to the objects to smooth out any erratic motion from the affected physics objects. |
| Randomness | Randomises the force amount per object. |
| Mode |
The mode of the affector
| Falloff Mode |
| Falloff Direction |
| Falloff Easing Mode |
