Primitive Weight
Primitive Weight
Updated: 15 Jan 2026
Generate particle weight values using 3D primitive shapes.
This node generates particle weights based on 3D primitive shapes.
You can generate instances of this node by connecting a transform array into the "Transform Array" input, much like you can with a normal 3D primitive. Allowing you to create more complex particle weight shapes.
Primitive Type Choose which 3D shape to generate the weight with.
  • Box : Use a box as the weight generator shape.
  • Cylinder : Use a cylinder as the weight generator shape.
  • Sphere : Use a sphere as the weight generator shape.
  • Plane : Use a plane as the weight generator shape.
  • Cone : Use a cone as the weight generator shape.
  • Pyramid : Use a pyramid as the weight generator shape.
  • Torus : Use a torus as the weight generator shape.
Box Size X Set the size of the box along the X axis.
Box Size Y Set the size of the box along the Y axis.
Box Size Z Set the size of the box along the Z axis.
Box Bevel Radius Set the radius of the bevel on the edges of the box.
Cylinder Radius Set the outer radius of the cylinder.
Cylinder Height Set the height of the cylinder.
Sphere Radius Set the outer radius of the sphere.
Cone Base Radius Set the radius of the base of the cone.
Pyramid Size X Set the size of the pyramid along the X axis.
Pyramid Size Y Set the size of the pyramid along the Y axis.
Pyramid Size Z Set the size of the pyramid along the Z axis.
Torus Inner Radius Set the inner radius of the torus.
Torus Outer Radius Set the outer radius of the torus.
Fill Mode How should the shape calculate the weight.
  • Filled : The shape is filled, so everything within the shape will be added to the weight.
  • Shell : Only the shell of the shape will be added to the weight. Everything within the shape will not.
Invert Value Invert the value of the weight.
These properties control the falloff of the primitive weight.
Falloff Mode Method of applying the falloff.
  • Off : Do not use falloff, only add the base primitive to the weight.
  • Spherical : Extrude a spherical falloff from each point of the base primitive, adding a falloff outward of the primitive.
Transform Array SourceSource Transform Array to generate clones of the primitive from.Transform Array
Falloff NodeUse an input node to control the properties of the falloff.Falloff
