MIDI Note Modifier
MIDI Note Modifier
Updated: 14 Aug 2025
Reads note values from a MIDI device.
This node reads note values from channels of a MIDI keyboard device so they can be used to control values on other nodes.
The MIDI note modifier listens to a specified MIDI channel on a specified MIDI device. The node will output the value of the newest MIDI note that has been played on that channel.
You must first add the MIDI device in the Notch Midi Mapper. Go to Project -> Settings -> Audio -> MIDI.
If you are looking to cause triggers caused by a specific MIDI note, look at the MIDI Modifier
Current Value Shows the current value of the effect. Cannot be directly changed.
Channel Choose which MIDI channel to use for the modifier.
CC Select which control change to modify the channel.
Use Recorded Value Uses the recorded MIDI files, instead of the live input from a MIDI device.
Listen For Channel/CC Listen for the incoming MIDI device.
Recording.. Start recording changes in the current value, to save to as a sequence of keys on a newly created attribute.
Offset Offset the current value of the incoming
Recorded Value The currently recorded value being used.
