Bake Modifier
Bake Modifier
Updated: 30 Sep 2025
Bakes incoming modifier values to the timeline.
This node takes incoming modifier values and bakes them to keyframe values on the timeline. Used to generate animation keyframes that are locked and repeatable.
Bake Now.. Bake incoming values to keyframes on the timeline. Will save all value data for the length of the node’s time segment in the timeline.
Current Value Shows the current value of the effect. Cannot be directly changed.
Incoming Value Displays the current unbaked incoming value.
Baked Value Displays the current baked value.
Pass Through Set wether to use the Baked Value data or the Incoming Value data.
Bake Frame Rate Set the rate at which values will be baked to keyframes.
Incoming ValueValue source to use to bake.Math Modifier
